Re: serial number
Posted by Dave_Id on September 27, 2003 at 22:41:26 from (67.75.192.161):
In Reply to: serial number posted by thomas on September 27, 2003 at 21:23:00:
You can tell by looking up the serial number under "Research & Info" at the left hand column of this page under "Serial Numbers", then tell us what you find
Post A Followup
: Re: Re: serial number
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
