Re: IH magneto
Posted by parts man on September 28, 2003 at 12:17:27 from (142.166.251.92):
In Reply to: IH magneto posted by Thomas T. in S.C. on September 28, 2003 at 07:45:30:
Thomas, take off the cover over the coil, clean the 2 contacts, one on the coil one on the cover. Look closely and make sure they line up when the cover is replaced. Make sure the contact to the coil wire in the cap is not corroded. If that doesn't do it it's probably a weak coil. Hope this helps.
Post A Followup
: Re: Re: IH magneto
