Re: Re: Re: Super M - not moving water
Posted by Bob M on September 28, 2003 at 16:47:20 from (66.66.126.214):
In Reply to: Re: Re: Super M - not moving water posted by bbauman on September 28, 2003 at 09:19:31:
The pump driver is kinda tough to describe - and I don't have a picture of one because they're nearly impossible to photograph without removing the radiator. However the driver consists of a piece that fits over the water pump shaft. The driver has two "arms" that engage a pair of pins that thread into the front face of the fan pulley. There's pair of small springs that fit over the drive pins between the driver arms and the fan hub.
Sounds as if you are missing the entire driver assembly. Probably your best bet is to visit a boneyard and try to buy an entire fan hub assembly with the driver installed. The CIH dealer might have though I suspect it's a very low demand item.
Good luck!!
Post A Followup
: Re: Re: Re: Re: Super M - not moving water
