Re: Throttle has no effect
Posted by 49 Cubber! on September 29, 2003 at 17:58:05 from (206.74.216.157):
In Reply to: Throttle has no effect posted by shuckpin wadley on September 29, 2003 at 10:29:41:
Assuming you mean the rod that goes to the carb it self when you refer to the "governor",move the throttle back and forth and see if the rod to the carb is moving,and the linkage from the throttle handle to the governor isnt binding.Also make sure the spring is in place.If all looks fine then its probably a worn throttle shaft,if not its either a problem in the governor,or the woodruff key in the linkage that goes over to the carb is sheared off.
Post A Followup
: Re: Re: Throttle has no effect
