Re: IH 5488 MFWD Front will not pull
Posted by RickB. on September 30, 2003 at 17:15:11 from (205.231.146.114):
In Reply to: IH 5488 MFWD Front will not pull posted by Dan on September 30, 2003 at 16:04:37:
The front driveshaft turning tells you nothing about the problem. It turns whether the clutch is engaged or disengaged because it is directly connected to the front diff pinion shaft. When MFD is turned off, the front wheels drive the shaft. The MFD clutch on every tractor I know of is between the rear of the front driveshaft and the rear axle pinion shaft; a split is likely to service it. Most of these clutches are hydraulic pressure off and spring pressure on. That is why they default to engaged when the tractor is shut off.
Post A Followup
: Re: Re: IH 5488 MFWD Front will not pull
