Re: Farmall A head gasket replacement
Posted by Randy in NE on October 01, 2003 at 04:22:52 from (216.58.237.20):
In Reply to: Farmall A head gasket replacement posted by Mike on September 30, 2003 at 18:39:43:
Besure to measure the diameter of your pistons. I just recently replaced the head gasket on my '50 C. It has 3 1/8 in pistons in it instead of the orginal 3". I had trouble finding the correct head gasket. The 3 1/8" head gasket assumed that you were working with a Super A/B/C and that you had a water pump. The holes for the water ports are much smaller. Ended up drilling out the holes on the gasket so that they matched more closely the holes in the head/block. The head bolts are torqued to 80 ft-lbs. The manifold to 20 ft-lbs. The valves are set to 0.014 in. After you get it running again you need to warm it up and then re-torque the head bolts. This requires you to remove the valve rocker arm and re-set the valves. While you have it apart clean all of the carbon build up off the head and the top of the pistons. It would be a good time to check for valve wear. I was able to push on the valve stem and give it a quick visual. Not the most scientific but at least I didn't see anything of significance. You would also want to take a good straight edge and check the top of the block and the head to see if they are warped. Cleanliness is next to Godliness. There was a post yesterday that suggested using brake parts cleaner to wipe the surfaces of the head and block. Some kind of gasket sealant will help to keep you from doing this again. Some use the spray on kind. I used a high temp silcone sealant. Which ever you feel more comfortable with. I am sure that I have missed a couple of things but this gives you some things to look for. There was also a post yesterday about oil flow to the rocker arms and not using a locker washer on the center bolt. That would be worth reviewing. Good luck.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
