Re: Re: 3414 Brakes
Posted by JB on October 01, 2003 at 17:47:20 from (24.157.143.220):
In Reply to: Re: 3414 Brakes posted by Mike on October 01, 2003 at 16:16:49:
Hi, I assume the 3414 is the industrial version of the B414, made in the UK but possibly assembled in USA. On the B414D we used to take the brakes apart and clean the roller balls and tracks, apply a very small amount of high temp grease of the balls, then take a wire brush and roughen the surface of the disk pads. Basically get the shiny glaze off them.
One time a neighbor replaced the disks and his brakes were worse and the problem was the new disks were riding up on the ridge that had been worn into the outside diameter of the metal brake facing. He had to take a file and file the outside edge of the new disk so they would fit tight against the metal brake facing.
Good luck
JB
Post A Followup
: Re: Re: Re: 3414 Brakes
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
