Re: Re: 3414 Brakes
Posted by the tractor vet on October 01, 2003 at 18:24:59 from (216.196.13.186):
In Reply to: Re: 3414 Brakes posted by Mike on October 01, 2003 at 16:16:49:
The brakes on them did leave alot to be desired . If you can find the imported brake disc's they have the asbestos lining and a nother thing that does help SOME is assembal the brakes into the drum with the expander and take a massurement with a stright edge and see just how much clearance you have between the stright edge and the disc then mill it off so you have around .125 clearance. What has happed is that with normal ware there is to much clearance and the expander is comming out to far and losing it's max force.
Post A Followup
: Re: Re: Re: 3414 Brakes
