Re: 350 utility motor in an H?
Posted by Donnie on October 02, 2003 at 07:31:50 from (67.241.18.187):
In Reply to: 350 utility motor in an H? posted by Farmall Daddy on October 01, 2003 at 18:52:06:
Yes it will fit. Done it several times. The front timing cover has to be changed. The flywheel will also have to be changed. You'll have to put your H clutch disk, and pressure plate back on the 350 motor. The H does'nt have the large input shaft like the 350. Hope this helps.
Post A Followup
: Re: Re: 350 utility motor in an H?
