Re: THe BN is running once again.
Posted by Gary_N_WV on October 02, 2003 at 12:42:35 from (129.71.234.254):
In Reply to: THe BN is running once again. posted by Kevin in Michigan on October 02, 2003 at 10:37:32:
Kevin,
Is this the same tractor that your machinist screwed up the crank by cutting to .040 under or was that someone else's post.
What did you do to fix the rocker oil problem? Use JB Weld as you mentioned?
Gary
Post A Followup
: Re: Re: THe BN is running once again.
