Re: SMTA repairs
Posted by Dr.EVIL on October 02, 2003 at 14:53:59 from (12.4.181.2):
In Reply to: SMTA repairs posted by Chad on October 02, 2003 at 13:23:31:
Rear axle oil seals aer easy to replace. Remove the erar wheels/tires, slide them off the ends of the axles, remove the 4 small capscrews on the bearing/seal retainer plate. Dig the felt out, scrape the old gasket off, slide the seal, retainer,felt assembly over the axle bar, install & tighten the 4 capscrews, replace the wheel and your done. I smear some grease over the axle bar to save wear & tear on the seals. Parts for My Super H were maybe $10-$12 per side. Never split a tractor to replace a T/A but I would recommend a hard copy manual unless You have a REAL good printer for Your PC.
Post A Followup
: Re: Re: SMTA repairs
