Re: Farmall 450 Diesel Starting Problems
Posted by AL-450 on October 02, 2003 at 19:29:19 from (67.250.223.99):
In Reply to: Farmall 450 Diesel Starting Problems posted by Owen on October 02, 2003 at 09:27:17:
Bill,
I bought a 450-D several years ago that smoked terrible and ran badly on gas startup What I did to cure it was to advance the distributor timing. It now starts fine on gas with almost no smoke and the RPMs are much higher. So something you can try. I always switch my 450-D and my MD to gas cycle for a few seconds before shutting off the ignition switch. But then I switch it back to diesel cycle.
Post A Followup
: Re: Re: Farmall 450 Diesel Starting Problems
