Re: Farmall 450 Diesel Starting Problems
Posted by farmallgod on October 03, 2003 at 10:24:07 from (64.12.97.12):
In Reply to: Farmall 450 Diesel Starting Problems posted by Owen on October 02, 2003 at 09:27:17:
Had the same problem with an MD you have to make sure the linkages are adjusted right or you will get some diesel in there. On the left side of the motor where all the linkages come together make sure you have full motion.
Post A Followup
: Re: Re: Farmall 450 Diesel Starting Problems
