Re: Re: Removing front flat tire on 47 M
Posted by Harold H on October 03, 2003 at 10:27:55 from (67.30.243.34):
In Reply to: Re: Removing front flat tire on 47 M posted by Stuart Martin on October 03, 2003 at 09:21:51:
That won't work. he has a single front. You must jack up the front, remove the safety bolts in the bottom of each side of the fork, then loosen the big nuts and the wheel and axle will drop down, Then you can take the wheel and tire to the tire shop if you don't want to fix it yourself.
Harold H
Post A Followup
: Re: Re: Re: Removing front flat tire on 47 M
