Re: Re: Re: PTO Generators
Posted by Roger on October 03, 2003 at 19:56:09 from (216.248.104.132):
In Reply to: Re: Re: PTO Generators posted by kjm on October 03, 2003 at 19:36:14:
KJM, I didn't run it with the MM tractor very long, not enough to tell how much fuel it would use, maybe 10-15 minutes. With a stand alone unit, it's another engine to do maintenance on. If I need to do a weld or other repair in the field, I already have a tractor there to run it anyway. Other than that, I don't know of any drawbacks to a stand alone unit, if you were going to use it a lot, the stand alone would be faster than hooking up a pto shaft all the time, just turn the key!
Post A Followup
: Re: Re: Re: Re: PTO Generators
