H Throttle Rod Configuration
Posted by Jim in Ontario on October 04, 2003 at 17:22:24 from (216.58.103.90):
I must be loosing my mind I just reinstalled my throrrle rod and could not remember how it went back together... there is a u shaped bracket, 2 springs,the block that the cotter pin goes in, 2 nuts and the throttle rod.
I slid one side of the bracket on then one spring then the block that the cotter pin goes in then the other spring the other side of the bracket then finaly the two nuts.
if this is right then why have I got to move the govener lever to wide open before there is an increase in engine speed?
Thanks in advance
Jim
Post A Followup
: Re: H Throttle Rod Configuration
