Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Fa
Posted by George Willer on October 05, 2003 at 18:52:44 from (66.242.44.119):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Farmal posted by Hugh MacKay on October 05, 2003 at 16:52:48:
I plan to follow up on this with the club. By the time it can be arranged, I'll be 70. Anyway, that won't change the basic premise. Yes, adding weight to the rear axle will make it more dominant in the stability department, as will increasing the tread. You are quite correct.
I'll keep you advised as plans progress. If anyone else has a notion to do the same experiment, I think we'd all benefit from a report. It will be much more useful than claiming experience will over-rule physics, as another poster has.
Where are you from? We're in northern Ohio, not far from Cedar Point.
George Willer
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Fa
