Re: poping M
Posted by Steve - IN on October 05, 2003 at 22:17:28 from (12.222.30.13):
In Reply to: poping M posted by Bill on October 05, 2003 at 19:39:11:
Bill, I think you're on the right track. Popping out the carb is probably a timing problem of some sort. An intake valve is closing too late, or a spark plug is firing too early. If it only does it occassionally and randomly, it could be a wobble in the distributor shaft, short in the primary side, arc in the distributor cap, etc. If you set the valves cold, try for around .022 cold (which should be loose enough to answer the question about an intake valve staying open) then recheck when warm to see if the expanded metal has taken up the slack, or expanded less than expected - and you might find some in either direction. After you've found TDC compression for #1, just follow the firing order - think it's 1-3-4-2 for an M - and turn the crank a half turn, or 180 degrees for each set of valves in sequence of the firing order to be certain you're on the backside of the cam for each valve you adjust. Good luck in solving the problem.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
