Re: IH 240 engine miss
Posted by Billy McCarver on October 06, 2003 at 02:29:30 from (67.30.12.235):
In Reply to: IH 240 engine miss posted by B. Rust on November 01, 1999 at 18:55:57:
Hi, My grandfather had this problem after letting neighbors borrow his tractor. Calves had chewed the wiring on a TO-30 tractor and they had 'repaired' the damage. If you haven't found your problem to be something else by now, check the wiring at the coil as to polarity. The neighbors had wired the coil backwards causing the spark to jump backwards at the plugs. It would start and run ok but would begin missing as the engine warmed up and die after about 30 minutes without restart until the engine was stone cold. Hope this helps you.
Post A Followup
: Re: Re: IH 240 engine miss
