Re: Farmall B has noisy transmission
Posted by Larry on October 06, 2003 at 06:41:54 from (64.73.67.49):
In Reply to: Farmall B has noisy transmission posted by Ryan Correll on October 05, 2003 at 20:44:27:
Check for metal filings forming in your oil. If you cannot see some in your oil, the best way to do this is do JB weld (glue) a small magnet onto your drain plug and screw it in. They do tend to lose bearings.
Post A Followup
: Re: Re: Farmall B has noisy transmission
