Re: Found while draining rear end. Help.
Posted by WIRED on October 06, 2003 at 14:09:46 from (156.46.176.10):
In Reply to: Found while draining rear end. Help. posted by Jay on October 06, 2003 at 13:56:26:
Sounds to me like a chassis dowel pin. There is a smaller dowel pin in the PTO too, but I suspect you'd have trouble engaging/disengaging the PTO if that pin worked loose.
I found the PTO thrust bearing floating around in my chassis after I took the top cover off. Part of my left wheel bearing cage was also floating around in there.
Post A Followup
: Re: Re: Found while draining rear end. Help.
