Re: HELP...I just got bit on a 47 A and need advic
Posted by Randy in NE on October 07, 2003 at 06:22:06 from (68.99.25.138):
In Reply to: HELP...I just got bit on a 47 A and need advice... posted by Jesse on October 06, 2003 at 14:23:11:
Just to add to a couple of the other posts. Pre-mix the anti-freeze prior to pouring into the radiator. Mix it per the manufacturer's instructions. Usually a 50-50 mixture protects to the lowest temperatures. The A has the same block as the C. My C does NOT have a water inspection port on the side of it like the bigger tractors. Removing the radiator hoses and flushing it out good with water will most likely do the trick. With the engine cold you could remove the radiator cap (carefully) and then start it up. You can check the flow of water coming from the upper radiator hose. You can either use a thermometer or your finger to see if it is starting to warm up. Just be careful that you don't burn yourself. Good luck.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
