Re: H gas tank removal ? Help please
Posted by Steve - IN on October 07, 2003 at 06:26:59 from (12.222.30.13):
In Reply to: H gas tank removal ? Help please posted by Two Bit on October 07, 2003 at 06:13:27:
Two Bit,
Those bolts are really studs. If you keep spinning them, they'll spin right out the bottom of the tank. At that point the tank is free (once you've disconnected the fuel line) to remove. You can then soak the studs and castle nuts in penetrating oil and work on freeing them in a more convenient position than upside down under the tank.
Post A Followup
: Re: Re: H gas tank removal ? Help please
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
