Re: Changing Transmission Fluid on a Farmall 450.
Posted by Steve450 on October 07, 2003 at 17:00:07 from (64.78.90.155):
In Reply to: Changing Transmission Fluid on a Farmall 450. posted by Matt Croft on October 07, 2003 at 09:07:05:
Matt,
To change the trans oil, you need to pull the big drain plug under the pto shaft and also the little drain plug on the front of the transmission case. Be aware that the trans/ rear end holds around 15 gallons of oil, so have enough buckets ready to catch it all. The small 3/8 plug in the front only holds a small amount, but needs to be drained also. To fill, just install the drain plugs and remove the small cover to the right of the gearshift (3 bolts) and dump it in. There is a check plug on the left side of the trans about half way up the side. Remove that plug and fill the case until oil comes out of that hole. If it has been a while since the oil has been changed, you could fill with kerosene and drive it around for a few min to flush it out. You can buy manuals for a few dollars on this site that will help alot in keeping your tractor serviced and adjusted properly. You'd be surprised how many service points and adjustments there are!!
Post A Followup
: Re: Re: Changing Transmission Fluid on a Farmall 450.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
