Farmall Tractors Discussion Board
Re: Sleeve puller
Posted by Village Blacksmith on September 28, 1999 at 15:16:03 from (205.188.199.31):
In Reply to: Sleeve puller posted by Phlogiston on September 28, 1999 at 13:03:05:
I had to pull sleeves on a 200 last year and I made one from scrap metal. Used 1/2 inch steel plate. One piece about 4.00 inches round, one piece about 6.00 inches square. Drilled a 3/4 inch hole in them in the center, found a long 5/8 inch bolt in the junk pile and pulled them easily. Be sure you don't let the bottom plate touch the camshaft. It's crude, but when in touble, I'll resort to about anything that works. Also, level out the studs on top so you don't bend one.
Post a Followup
: Re: Re: Sleeve puller
