Farmall Tractors Discussion Board
Re: Re: Re: help identify Farmall
Posted by Daniel on September 28, 1999 at 15:40:03 from (205.188.197.37):
In Reply to: Re: Re: help identify Farmall posted by p on September 28, 1999 at 14:26:29:
The serial number on the block will be similar to the serial number of the tractor, but it is not always the exact same. I have read that no attempt was made to keep them the same at the factory. Also, it's possible the block has been swaped (unlikly). I don't want to sound nit-picky, this is just info. I've found out researching mine.
If you can't find the serial number, the front end will indicate an A or B as already posted, look for date codes on major castings for the year model, something like 12-3-W. This would be Dec. 3, 1951. The letter is the year; A=1931 -Z=1954. V is not used, and U & W are both 1951. Good Luck
Post a Followup
: Re: Re: Re: Re: help identify Farmall
