IH 806 hydraulics
Posted by Roy on October 08, 2003 at 10:06:41 from (205.203.58.1):
I inherited an IH806. The tractor is diesel in good shape, runs very good. I just fininshed cutting and raking hay with it, did a great job. When I first got it, I noticed that the three-point raised and lowered very slow.
I attached the baler to the tractor, and it will not raise the tailgate on the baler (hesston 5585). This is with the rear remotes, should I try the front hydraulics, or is the hydraulic pump weak. If it is the hydraulic pump should I get it fixed or is it better to get out from under this tractor.
Thanks
Post A Followup
: Re: IH 806 hydraulics
