Re: Re: Super C, Water Pump
Posted by Haas on October 09, 2003 at 05:57:11 from (12.65.44.138):
In Reply to: Re: Super C, Water Pump posted by JT on October 09, 2003 at 03:22:05:
Pretty simple job to replace the water pump. It's only held on by two bolts, the hose and the fan belt. Best to get some new hose and clamps while you are at it. Hardest part is working around the fan shroud. Also, can't recall for sure, but I think WP is on the same side as the generator, so you have to remove the generator to get to it. Make sure you get a new gasket where the pump mounts to the block too. That gasket is usually part of the package if you buy a new or rebuilt pump. And...make sure the pump includes the pulley or you will be hunting someone with a press to change the pulley.
Post A Followup
: Re: Re: Re: Super C, Water Pump
