Question for Bob M
Posted by Peabody on October 10, 2003 at 11:19:07 from (68.117.180.116):
My Super C has the original 6 volt positive ground system. I swapped out the original generator which was not putting out with a known operable one. The ammeter indicates a good rate of charge, however, using a analog voltmeter only indicates an output of between 3 & 4 volts. I have cleaned the commutator twice. Will this rate of charge maintain a 6 volt battery? Any suggestions, short of a rebuild? Thanks for any help.
Post A Followup
: Re: Question for Bob M
