Farmall Tractors Discussion Board
Re: Re: Sleeve puller
Posted by Holloway on September 28, 1999 at 18:54:12 from (216.14.57.202):
In Reply to: Re: Sleeve puller posted by The Red on September 28, 1999 at 13:21:52:
If you have a bare block, you can weld a bead down the inside of the sleeve. It will fall out before you get the bead from top to bottom. This is only if the block is bare, no crank, cam or anything that might get slag on it.
Post a Followup
: Re: Re: Re: Sleeve puller
