Re: super a farmall
Posted by Hugh MacKay on October 11, 2003 at 16:00:01 from (209.226.106.74):
In Reply to: super a farmall posted by w plotts on October 11, 2003 at 10:28:47:
Yes you have to remove the front end. I have found the eaiest way is to loosen the left side at the adjustable tread section. Pull that side right out, then remove the pivot pin on front end. The U bolt that goes ubder axle is hard to remove without removing rad. By taking the front end in two pieces you make it easier to handle, and you eliminate the need for removing the U bolt. Chalk your rear wheels securely and place a jack under flat point on clutch housing. You then can remove bottom half of steering box. If it is looseness of steering check the woodruf keys on steering arm shaft. Bearings in steering wheel shaft if bad will give end play to the shaft.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
