Re: Farmall 300 clutch won't engage
Posted by Jailkeeper on October 11, 2003 at 20:42:12 from (216.174.160.141):
In Reply to: Farmall 300 clutch won't engage posted by Michael on October 11, 2003 at 20:11:41:
Sounds like the clutch disc is stuck on the input shaft. Try driving the tractor in low gear, pushing the clutch pedal down and engaging the brakes repeatedly. You have to stomp on the brakes until it nearly kills the engine, let off, and do it again. Keep trying it and hopefully it will "jar" the clutch disc loose. May also help to squirt some penetrating oil up through the bottom on the input shaft.
Post A Followup
: Re: Re: Farmall 300 clutch won't engage
