Re: Re: Re: FARMALL SUPER A - QUIT RUNNING!
Posted by Farmer Bob on October 12, 2003 at 18:13:38 from (64.113.13.50):
In Reply to: Re: Re: FARMALL SUPER A - QUIT RUNNING! posted by BILL IN VT on October 12, 2003 at 17:56:46:
Remove the distributor cap and rotor and crank the engine over watching for spark when the points open. Make sure they are gapped at .020" on high cam. If no spark suspect the coil or condensor. Replace the condensor first as it is cheaper than a coil. Keep trying until you have spark at the points. On the fuel side, shut off the fuel under the tank and remove the fuel line at the sediment bowl and then remove the bowl by loosening the bail that holds the bowl in place. Open up the shut off valve that you closed. Should hold a can under there to catch the gas as it should run a good stream. Make sure the screen at the top of the bowl is clean. Next remove the other end of the fuel line from the carb. Blow through the line to clean any obstructions. Now remove the fitting that the carb end of the fuel line goes into. There may be a screen on the inside end of this fitting and it may be plugged up. If there and dirty, clean it out. It could also be inside the carb where the problem is. Try these other things first and then post back. Someone will surely respond with more hints to get you going.
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
