Re: Super C Pan Bolts
Posted by Red Rider on October 13, 2003 at 20:03:33 from (66.248.101.136):
In Reply to: Super C Pan Bolts posted by Bud on October 13, 2003 at 15:41:12:
Hi Bud, I had the same problem with my Farmall 100. It has the same 123 as your Super C. I used the permatex thread sealer and stoped the leaks. I could not remember which holes are exposed to oil in the block so I just sealed the ones that were leaking.
Post A Followup
: Re: Re: Super C Pan Bolts
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
