Re: Re: Re: Super C Pan Bolts
Posted by Peabody on October 14, 2003 at 06:26:42 from (68.117.180.116):
In Reply to: Re: Re: Super C Pan Bolts posted by Bud on October 13, 2003 at 20:09:55:
Answer, "No." I know this from experience. The center bolts on the rear of the pan are not SUPPOSED to extend through the block. They use a shorter bolt. Not knowing this, I installed a longer bolt and pushed a hole through the block into the oil cavity. There was only about a 1/4" of block material between the bottom of the bolt hole and the oil cavity. Upon removal of the pan and inspection, the end of the bolt was precariously close to the bottom of the crankshaft. I assume it is the same with the front bolts. It is important to determine which pan bolt holes are for the longer and shorter bolts.
Post A Followup
: Re: Re: Re: Re: Super C Pan Bolts
