Re: Removeal of hydrlic pump on an H
Posted by Scott Swanson on October 17, 2003 at 10:03:02 from (209.180.31.9):
In Reply to: Removeal of hydrlic pump on an H posted by Chris on October 14, 2003 at 19:22:45:
Be careful with those open pipe holes. Be as careful as you can to keep dirt out of the pump.
I stack auto tires up to almost the bottom of the pump housing and then lay in three thicknesses of old clean carpet.
I yank the 4 bolts out and run.
I usually walk back through a river of oil. Gotta have some fun. Tractors are not all serious!
Post A Followup
: Re: Re: Removeal of hydrlic pump on an H
