Re: 706 Farmall steering hydraulic leak
Posted by Aces on October 18, 2003 at 10:20:33 from (67.0.6.205):
In Reply to: 706 Farmall steering hydraulic leak posted by Mark A.McCall on October 18, 2003 at 04:54:36:
That is where you can get at the rack that does the steering should be a O Ring behind the plate will loose some oil but not much may have to take the side rail of to get at it you should see the end of the raik and the flange of the sleve the rack is in the sleve can be turned so the rack can be adjusted up to the bolster shaft to that play out but you should not have to do anything with that.
Post A Followup
: Re: Re: 706 Farmall steering hydraulic leak
