Weird oil leak on 706 #930
Posted by Bob on October 18, 2003 at 20:30:07 from (66.163.134.177):
We put a TA in a diesel 706 for a customer, recently, and a rear main seal, as he complained it had been leaking for years. For so may years, in fact, that he had the dealer put a rear main seal in it years ago... and the dealer's been gone since the mid 70's!
Anyhow, it still leaks from the clutch housing. We tracked down the leak. There are steel pipes cast into the actual cast-iron belly-section of the tractor for various hydraulic functions. The pipe that carries the power steering valve supply oil from the MCV up to the steering valve has a flaw in it up inside the casting of the flywheel housing, directly behind the clutch release fork shaft, on the LH side of the tractor, causing it to ooze HyTran into the clutch housing!
Has anyone encountered this before? I'm sure this must have leaked since new, and the dealer did not track down the source of the leak. We are going to try to plug both ends of the internal oil passage, and route an external oil line from the MCV to the steering valve. Anyone have any thoughts on this?
Post A Followup
: Re: Weird oil leak on 706 #930
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
