Re: Farmall C Bolt hole ?
Posted by Randy in NE on October 19, 2003 at 19:20:19 from (68.99.25.85):
In Reply to: Farmall C Bolt hole ? posted by Gary_N_WV on October 19, 2003 at 17:37:03:
I have a 3/4" hole on each side of the transmission torque tube right below the battery. I also have a pair of 5/8" holes on each side right below the hydraulic unit on a small machined flat spot. I don't have anything that bolts there but I'm sure that there is something like a mid-mount blade or belly mower. Maybe even something like the cornpicker or some other implement. I'm sure that Farmall had a use for it or it wouldn't have been there.
Post A Followup
: Re: Re: Farmall C Bolt hole ?
