Re: brakes on a Farmall B
Posted by gene b on October 20, 2003 at 11:59:08 from (67.1.108.22):
In Reply to: brakes on a Farmall B posted by hal on October 20, 2003 at 04:09:44:
Get some good blocking the drivers side is by the fender the other side is by the transmission. I use a cherry picker as the final drives are heavy i use a strap to go around the assys when taking apart. You should be able to get linning at a brake shop for around 25 and reline them yourself. I also turn the drums on a lathe with a sharp tool to get rid of the glaze and then realy have great brakes. Mite want to replace the seals as by now they probably are leaking grease from either the trans or the final drive. You can get them from CAR-QUEST for around 24 each. E-mail if you need their part number.
Post A Followup
: Re: Re: brakes on a Farmall B
