Re: H Magneto
Posted by bindernut on October 20, 2003 at 21:15:28 from (65.69.46.96):
In Reply to: H Magneto posted by Ronnie on October 20, 2003 at 16:45:13:
I'd say keep the mag. check the cap, wires, points & condensor. Coil's built into the mag, or i'd say try that.
If you switch to a distributor system you can't run it if the generator ever dies or the battery is shot. Just the other day we were running our H without a battery in it. Used the bat. to start it, then put it in the m to charge it. (h has a dead generator)
6 or 12 volts won't matter to the mag either. Need to change the coil or add a resitor if you're running a distributor system.
Bindernut
Post A Followup
: Re: Re: H Magneto
