Re: Re: Re: Re: Governor on IH 140
Posted by David on October 21, 2003 at 09:23:21 from (209.192.126.1):
In Reply to: Re: Re: Re: Governor on IH 140 posted by Stan(VA). on October 20, 2003 at 20:00:46:
Thanks, I will check the rock shaft and if I need to I pull the governor back off and check the spring.
My father bought this tractor about 2 years ago, then it would idle but it would not open up all the way, it would open up enough to use it but that was all. We took all of the sheet metal, tires, radiator and almost everything else off to clean it up and paint it, we did not take anything off the engine except the carb. When we put it back together it would not idle correctly but would open up more. I then tried to adjust the governor and then took it off and could not find anything wrong. It has worked well enough to use for the past year or so. It is a 71 model he bought from the local tractor dealership, not sure where they got it, but who know what parts have been changed in 30 years. I will spend some more time on it.
Post A Followup
: Re: Re: Re: Re: Re: Governor on IH 140
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
