Re: 1206 turbo and pump questions
Posted by carl b on October 21, 2003 at 19:06:34 from (208.40.152.243):
In Reply to: 1206 turbo and pump questions posted by Chad on October 20, 2003 at 19:18:30:
about your turbo question the whistleing noise is normal its building boost press. To check the turbo for normal operation you need to put a boost gauge on it the gauge should read somewhere between 0 and 100 pounds boost press. you would have to see what the manufacture spec is. A turbo wont build full boost until you have a load on the engine. You should also check the turbo internally remove the intake side and ex side and check impeller shaft for excesive in and out and side to side play. You mayalso see small amounts of oil on the intake side which is ok but the ex side is bad to see oil. good luck
Post A Followup
: Re: Re: 1206 turbo and pump questions
