Re: Farmall H and M transmissions questions
Posted by dave s. on October 22, 2003 at 06:58:47 from (66.128.177.23):
In Reply to: Farmall H and M transmissions questions posted by Rick in MD on October 21, 2003 at 12:34:47:
I have an h, super h , and 3 m's an we have only replaced one bull gear in the h. However I know of some of these tractors that have had a bearing go out and they have cracked the rear end case because there is no clearance between the gears and the housing so when a piece of the bearing gets wedged between the gear and the housing you can crack it or even put a hole through it.My neighbor's m had this happen so he had it welded back together, put new bearings in it, and uses it daily on a loader with no problems.The problem with ALL older tractors is they always seem to get a certain amount of water in the gear lube.
Post A Followup
: Re: Re: Farmall H and M transmissions questions
