Re: Re: M WFE help
Posted by Shawn on October 23, 2003 at 14:49:06 from (152.163.252.227):
In Reply to: Re: M WFE help posted by Allan on October 20, 2003 at 18:07:54:
I think a change in torches might help. I use a propane torch that heats a large area, it uses a 20 or 100 lb cylinder. Its a small tube feeding a 2 1/2" pipe. They are available at welding supply stores or at Norhtern tool. They are cheaper to use & will heat your tube more evenly than oxy/acet. cutting torch. I would get whole tube above 300 deg., spit on it if spit flies off rather than sticking your there, then apply the blaster as it cools, a big pipe wrench or chain wrench may help in working it front to rear to loosen. My 2 cents
Post A Followup
: Re: Re: Re: M WFE help
