Re: Draining a Farmall A radiator...
Posted by tractorhead on October 25, 2003 at 11:45:57 from (206.150.180.79):
In Reply to: Draining a Farmall A radiator... posted by Jesse on October 25, 2003 at 09:37:39:
being a retired pump machinist i have removed many a frozen pipe plugs.removeing a pipe plug is different from trying to remove a bolt or nut.a plug is made to seal and that it does,where a bolt hase thread clearance a plug does not,therefor no amount of pentitrating oil will help,also i almost never had luck with an ez out.now having said all this, if you can weld a nut on the stud of the plug this may work the weld has to be very good as the plug at this point is proba bly just about welded it self to the radiator,also the plug could be brass or cast then it will have to be brazed (not easy} if that does not work, next file the end of the plug flat so we can drill,it must be flat or the drill will walk off center start with a smaller drill keep getting larger stop when the drill just touches the root diameter of the taped hole,with a very small round nose chisle you should be able to work it out,it you ding it dont worry you can always tap it deeper it you are lucky enough to drill dead center you may just be able to tap it. have faith you can do it.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
