Re: Draining a Farmall A radiator...
Posted by moonlite on October 25, 2003 at 14:18:20 from (64.82.207.23):
In Reply to: Draining a Farmall A radiator... posted by Jesse on October 25, 2003 at 09:37:39:
Are you sure you are finding the right drain? There is a small pipe CAP screwed over a smal pipe nipple to drain the cooling system. No pipe plug. Any good pair of locking pliers (Vice Grips)should work.
Post A Followup
: Re: Re: Draining a Farmall A radiator...
