Re: 300 U Questions
Posted by Charlie on October 26, 2003 at 08:04:14 from (209.130.219.52):
In Reply to: 300 U Questions posted by Dan on October 26, 2003 at 06:25:51:
The transmission problem could be the tractor is locked in 2 gears. Many of the IH tractors of the 40's and 50's had that problem. I'm not sure if you can take the top off where the shifting lever sits on the transmisson but if you can you can pry the gear back into place. On the steering, do you have power steering or manual. Does the shaft coming out of the steering unit turn. If its manual steering, there is a screw that keeps the gears meshed inside the gear box and it affects the right sight. I'm not sure what it has if its power steering.
Post A Followup
: Re: Re: 300 U Questions
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
