Re: Cleaning the rear gear box in the rear of a Fa
Posted by Haas on October 27, 2003 at 05:33:09 from (12.65.7.211):
In Reply to: Cleaning the rear gear box in the rear of a Farmal posted by Sam on October 27, 2003 at 03:54:30:
On the C, removing the PTO assembly willnot give full access to the transmission. The mounting bolts are the same as the A, but there is not a full sized hole there, only small openings for the shaft, etc. I think best would be to let it drain for at least 24 hours and then refill with gear oil. If what comes out looks really bad, then do it again in a month or two. If you do the diesel fuel flush, I'd suggest jacking up the tractor and running it that way to agitate. No load on the bearings and less chance of any damage that way.
Post A Followup
: Re: Re: Cleaning the rear gear box in the rear of a Fa
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
