Wannabe and Be-There Is Difference
Posted by Kajun on October 27, 2003 at 15:32:23 from (68.17.96.205):
Tractorfolk:
Often characterize myself as a mechanic wannabe.Probably proved it on Saturday.
Governor spring broke on my Cub; pulled radiator to replace spring . Couldn't figure a way to get to it w/o removing radiator.
Re-installed radiator using RTV in place of gasket which was badly worn. Pushed out RTV on the outside of radiator when I brought bolts all the way home. Now I suspect I did the same on the inside which means with hot radiator fluid I risk it coming loose and gunking the radiator up or the RTV lodging somewhere else in the system.
Any thoughts here? Any experience here? Must I pull the radiator off and start all over again? If so, how much RTV is too much?
Kajun
Post A Followup
: Re: Wannabe and Be-There Is Difference
